1995 Ford Ranger clutch
GREGORYHICKS
  • 1995 FORD RANGER
  • 4 CYL
  • MANUAL
  • 275,000 MILES
The clucth will not disengage I have changed the clucth slave cylender and bled the system about 20 times it will still not disengage can you tell me what else it could be
Tuesday, January 1st, 2008 AT 1:04 PM
  • 31,937 POSTS
Hi there,
Do you have good pressure in the system? If someone pushes the clutch can you see the fork move? Check for excessive pedal free play. (Free movement before you feel any resistance) if there is excessive clearance, see if you have an adjustable master cyl push rod, and adj as required, do this first.
Mark (mhpautos)
Wednesday, January 2nd, 2008 AT 1:53 AM
GREGORYHICKS
There is no adjustment on the push rod could it be a bad master clyender
Wednesday, January 2nd, 2008 AT 11:29 AM
  • 31,937 POSTS
If this feels like a pressure related problem, yes do the master cyl,
Mark (mhpautos)
Wednesday, January 2nd, 2008 AT 3:05 PM
