Clutch or transmission?
105,000 MILES • 2WD • MANUAL
FORDRANGER1995
1995 5speed, not driven in 4 months..no problems prior..NOW-start truck up with parking brake on, clutch in but will not shift into forward gears, REAL BAD GRINDING trying to get into reverse...Turn off engine, clutch allows me to go into 1-4 gears, put gear in 1st, turn truck on, will go forward but will not allow me to go to any other gear, and cannot go back into 1st gear..Clutch? Or Transmission?
Feb 23, 2016 at 11:16 PM
WRENCHTECH
  • 20,758 POSTS
You have a problem with the clutch but it's probably a leak in the hydraulic system, either the clutch slave cylinder or the clutch master cylinder.
Feb 24, 2016 at 12:33 AM
FORDRANGER1995
THANK YOU!!
Feb 24, 2016 at 12:41 AM
  • 55,781 POSTS
You are welcome, please post your findings to help others
Mar 7, 2016 at 7:52 AM
