1998 Ford Ranger
BRODERICK1
  • 1998 FORD RANGER
  • 4 CYL
  • MANUAL
  • 51,000 MILES
I have a slight viburation. When I release the clutch it goes away. I have had the clutch replaced. There is a little play where the driveline goes into the trans.
help.
Monday, March 3rd, 2008 AT 7:18 PM
SERVICE WRITER
  • 9,123 POSTS
I find it hard to believe that a clutch was needed on this truck. They can go over 150,000 miles.
I would check the front and rear u-joint. Primarily the rear. Have you heard a chirp or squeak when moving slowly at all? Look for a rusty look around the caps of the u-joint.
Monday, March 3rd, 2008 AT 9:11 PM
BRODERICK1
  • 8 POSTS
I have checked the u joints and they seem to be ok.
The clutch was changed because the pressure plate would squeek quit loud when depressed. Thanks again.
Tuesday, March 4th, 2008 AT 7:06 AM
BRODERICK1
  • 8 POSTS
Is there a bearing by the rear seal? There is a little play at that point.
Thursday, March 6th, 2008 AT 6:00 PM
SERVICE WRITER
  • 9,123 POSTS
http://www.2carpros.com/forum/automotive_pictures/30961_ranrr_1.jpg
Pinion?
Wheel bearing?
Thursday, March 6th, 2008 AT 6:04 PM
