How do I change the clutch pedal safety switch?
DIANESELF
  • 1995 FORD RANGER
Saturday, October 2nd, 2010 AT 11:26 AM
MERLIN2021
  • 17,250 POSTS
CLUTCH PEDAL POSITION (CPP) SWITCH Removal & Installation 1. Disconnect wiring harness from CPP switch. Pull orientation clip away from switch to separate it from locating pin. See Fig. 3 . Rotate switch until White plastic retainer is exposed. 2. Push tabs together and slide retainer toward push rod eye to separate it from switch. Remove switch from push rod. To install, reverse removal procedure.
https://www.2carpros.com/forum/automotive_pictures/62217_CPP_1.jpg
Tuesday, May 4th, 2021 AT 10:11 AM
