HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Climate Control
Air Conditioner
Compressor
Clutch
1995 Ford Ranger
JWPOTEET
MEMBER
1995 FORD RANGER
6 CYL
2WD
MANUAL
154,000 MILES
When I turn the airconditioning on the clutch on compressor will not engage
Friday, October 17th, 2008 AT 6:35 PM
OBXAUTOMEDIC
MECHANIC
Have you checked the freon, low freon will cause the clutch not to engage. If freon is full.
Check Low Pressure Switch, located on the Accumulator. To test just jump the terminals on the harness.
Post finding here in forum.
Friday, October 17th, 2008 AT 6:58 PM
Please
login
or
register
to post a reply.
Related Air Conditioner Compressor Clutch Content
Air Conditioner Clutch
The Clutch Plates Are Grinding, Turning When System Is Off, Noisy.
Asked by
nigel allison
1 IMAGE
1996
FORD RANGER
I Have A 1994 Ford Ranger V6 3.0l And The Ac Clutch...
There Is No Power Going To The Clutch And The Fuses Are Good.
Asked by
CT731
1994
FORD RANGER
1994 Ford Ranger Compressor Failer 2 Minutes After...
I Arched A Hole In My Manifold Hose (while Truck Was Turned Off) All Freon Leaked Out Of The Hose. I Made Sure Ac Was Off Before Starting...
Asked by
jjenkins9731
1994
FORD RANGER
1997 Ford Ranger Ac Compressor Kicking On And Off...
Why Does My Ac Compressor Kick On And Off Every 10 Seconds, And My Air Is Only Slightly Cold. When I Tried To Add Refrigerant, The...
Asked by
cclaar
1 ANSWER
1997
FORD RANGER
Compressor Will Not Engage
Air Conditioning Problem 6 Cyl Two Wheel Drive Automatic 175000 Miles The Ac On My Ranger Will Not Cool. This Started Last Fall As An...
Asked by
papadave
2 IMAGES
2001
FORD RANGER
VIEW MORE
Air Conditioner Compressor Replacement
AC Compressor Replacement Video
