1994 Ford Ranger compressor failer 2 minutes after professi
JJENKINS9731
  • 1994 FORD RANGER
  • 6 CYL
  • 150,000 MILES
I arched a hole in my manifold hose (while truck was turned off) all freon leaked out of the hose. I made sure ac was off before starting the truck. I took it to a repair shop in town and the replaced the manifold hoses (high and low) and replaced the freon. About a block or 2 after leaving shop there was a squeel ac quit working and compressor was smoking they said clutch was old and seperated. I was told by my dad that it happened because they didnt change the orifis tube (which got contaminated when I arched a hole in the metal hose) could not replacing that filter cause the compressor to freeze up and burn out the clutch? Any help will be greatly appreciated
Thursday, July 17th, 2008 AT 9:25 PM
KHLOW2008
  • 41,814 POSTS
Hi jjenkins9731,
If the compressor is not seized and only the clutch is damaged, it is not the problem of the filter.
The arching could have damaged the coils. Did you remove the battery negative terminal when woking on it?
Friday, July 18th, 2008 AT 3:56 AM
JJENKINS9731
The battery has top and side terminals, top if for the truck and side are for my power inverter. I removed the negative for the power inverter but the the one for the truck
Friday, July 18th, 2008 AT 7:44 AM
KHLOW2008
  • 41,814 POSTS
Hi jjenkins9731,
Nevermind about that now.
Test if the compressor is seized by turning the centre of the clutch centre plate. If it turns without much force then only the clutch is faulty so is not related to the pipe changes.
Friday, July 18th, 2008 AT 10:01 AM
