1994 Ford Ranger Cranks But Won't Start
EVERSOJOURN
Hi all, wondering if anyone can figure out what this is. I am turning my key over in the ignition. I hear it turning over but the engine won't start. Once in awhile it will give a buck like its about to start but that will be it. Any thoughts? Cheers.
Feb 20, 2007 at 7:53 AM
BOOTDOG
  • 665 POSTS
it could be a number of things. the thing you need to check is if the motor is getting enough fuel, spark and air. something simple as a restricted air filter could be a problem, a bad fuel pump or clogged fuel filter, fouled spark plugs, ignition module, etc. the thing you need to do is find out is, if it's fuel, spark, or air related. lets us know.
Feb 20, 2007 at 8:39 AM
Suggested Repair
Determine whether the no-start is fuel, spark, or air related. Check for a restricted air filter, failed fuel pump, clogged fuel filter, fouled spark plugs, and a faulty ignition module.
Conversation Summary
The owner of a 1994 Ford Ranger says the engine cranks but will not start, with only an occasional buck as if it is about to fire. The expert says the cause could be fuel, spark, or air and recommends checking those systems, including the air filter, fuel pump, fuel filter, spark plugs, and ignition module.
