For some unknown reason to me the new battery is being drained?
PHIL OGDEN
  • FORD RANGER
I have a 2002 Ford Ranger and recently replaced a dead battery. For some unknown reason to me the new battery is being drained. If it sits over night it will not start without a jump, but once it is started you can shut it off and start it all day.
Thursday, November 16th, 2006 AT 7:01 AM
BRUCE HUNT
  • 3,754 POSTS
If your 2002 Ford Ranger's new battery is being drained overnight, there may be an issue with the vehicle's electrical system causing an excessive parasitic draw. A parasitic draw occurs when an electrical component or circuit continues to draw power from the battery when the vehicle is turned off. Here are some steps to diagnose and address the problem:
Check for Accessories Left On: Ensure that no lights, radio, or other accessories are left on after the vehicle is turned off. Sometimes, a simple oversight can lead to a drained battery.
Perform a Battery Load Test: Test the new battery to ensure it's holding a proper charge and is in good condition. A battery load test will help determine if the battery itself is the problem.
Inspect the Charging System: Make sure the alternator is functioning correctly and charging the battery properly when the engine is running. A malfunctioning alternator can lead to a discharged battery.
Check for Parasitic Draw: Use a multimeter to measure the current draw when the vehicle is turned off. If the draw exceeds normal levels (usually a few milliamps), there may be a parasitic draw.
Isolate the Problem Circuit: Once you've identified a parasitic draw, you'll need to isolate the problem circuit. Start by removing fuses one by one and monitor the current draw with the multimeter. When the draw drops to a normal level, you've found the circuit responsible for the drain.
Inspect Components on the Problem Circuit: After identifying the problem circuit, inspect the components on that circuit for potential issues. It could be a faulty relay, switch, module, or even a wiring issue.
Check for Recalls and Technical Service Bulletins (TSBs): Check if there are any recalls or TSBs related to battery drain issues for your specific Ford Ranger model year. You can check with a Ford dealership or search for TSBs online.
Thursday, November 16th, 2006 AT 7:25 AM
DONNA EXUM
  • 2000 FORD RANGER
  • 6 CYL
  • 175,000 MILES
When driving the battery drains and battery light comes on. Had alternator checked and that was not problem.
Monday, May 12th, 2025 AT 8:48 AM (Merged)
CARADIODOC
  • 34,367 POSTS
Something was overlooked because if the generator is working, the "Battery" light would not be on.
Use a digital voltmeter to measure the battery's voltage while the engine is running. It must be between 13.75 and 14.75 volts. If it is low, we will need to measure the voltages on the smaller wires in the plug at the rear of the generator.
TYCOON
  • 1999 FORD RANGER
  • 6 CYL
  • 4WD
  • 128,000 MILES
This has recently happen about two days ago I notice that my battery gage was going down when I came to a stop than as I started to take off the gage would go back to normal and this keeps going on and I feel I might have a bad battery or my altenator is going bad. I recently put a new altenator on the truck about one year ago. Any help would be greatful.
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Since this is happening at idle I would have to suspect either the alternator is going faulty or perhaps the drive belt around the alternator is loose or damaged. Have the alternator and battery tested and inspect the drive belt.
Thanks for using 2CarPros. Com!
SURVEYTAKER1958
  • 1999 FORD RANGER
  • 4 CYL
  • MANUAL
  • 15,600 MILES
My battery light keeps coming on and low battery indicator keeps coming on while I'm driving. I took it in and had the battery, alternator, and starter checked and they said it didn't show any problems but the light only comes on when I'm driving, so they said it wouldn't tell them anything unless the light was on. It doesn't come on when I'm coasting or idling and it starts right up.
Check and test the ALT fuse 30amp and fuse no.15 7.5 amp and wiring to and from the alternator, also belt tension.
https://www.2carpros.com/forum/automotive_pictures/12900_alty_69.jpg
MGH CUSTOM GRAPHICS
  • 1997 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 167,000 MILES
Battery drains after sitting overnight when outside temperture drops below 35 degrees F. ?
Radio, fan, lights, etc are all off.
Runs and starts fine once it's started and battery is recharged.
Thanks,
Miike @
M.G.H. CUSTOM GRAPHICS
www. Myspace. Com/mghcustomgraphics
BLUELIGHTNIN6
  • 16,542 POSTS
How old is battery? Have you had it tested as well as the alternator? Great info. about this issue can be found at the link below.
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Let me know what you find after reading through that info. and I will follow up.
Thanks for using 2CarPros.com!
MGH CUSTOM GRAPHICS
Battery is brand new and alternator still charges when running. Its only when air temp drops below a certain degree
BLUELIGHTNIN6
  • 16,542 POSTS
Are battery terminals and wires free of corrosion and tightened properly?
Monday, May 12th, 2025 AT 8:49 AM (Merged)
MGH CUSTOM GRAPHICS
Yes. Terminals are new and tightened properly
RESQ12345
  • 1996 FORD RANGER
  • 6 CYL
  • 4WD
  • 100,023 MILES
I have a 1996 Ranger with a consistent battery drain. I have ruled out both the battery (by replacing multiple batteries) and the alternator (by having tested). Here is what I have observed so far. When I place an ammeter in line with the neg battery terminal and neg battery post, with the doors all closed, and before the GEM shuts down, I am showing.23 amps. When the GEM shuts down after 40 minutes or so, the current reading goes down to.15 amps. Now I start pulling fuses. (I use a screwdriver to close the door latch so I can get at the fuse box with the door open.) When I come to the large fuse in the main fuse box under the hood labled FUEL SYSTEM / ANTI THEFT SYSTEM and pull it, the current reading goes down to.05 amps (which is considered normal by ford standards). I have read that there is a TSB from ford regarding fuel pump and ecm relays sticking and causing a batery drain, so I replaced these relays, with no luck. I can't hear the fuel pump running, nor does there seem to be any problems with my factory antitheft, although I have no idea where the module is to disconnect it. One thing I did notice is that my gas gauge stays put (energized?) With the ignition off. I have no idea what else to check. Someone please help before I pull out all of my hair.
BLUELIGHTNIN6
  • 16,542 POSTS
You need to get the alternator tested as well to rule that out. Part stores will test for free, on or off of vehicle. Cold weather is harsh on the charging system. There are a few items you can purchase that are really handy in the winter for this problem. A trickle charger will keep your battery charged in cold weather. Heated insulator will keep the battery warm which in turn will keep it charged.
BUDDYCRAIGG
  • 2,262 POSTS
I'm looking at your schematic.
And fuse #12, a 20 amp MAXI fuse
goes straight to the fuel pump relay.
If you unplug the relay and the draw is still there, then it has to be the RAP module.
There is only one connection between the fuse box and the RAP, and that is directly at the RAP (C409). So I would assume that it has to be close to the fuse box.
I'll keep looking for a location for you.
BUDDYCRAIGG
  • 2,262 POSTS
It says, left rear corner of cab,
I'm still looking for a picture.
BUDDYCRAIGG
  • 2,262 POSTS
No picture.
But it says module is located behind trim panel at driver-side B pillar.
Disconnect negative battery cable, unplug 22 pin connector first, then 26 pin connector.
RESQ12345
I found the RAP module and disconnected it and the current draw went away. My question is: what SHOULD be the correct current draw? I have had no problem with the anti theft system. Also, could a remote relay be causing the drain? I would prefer to replace a relay first before replacing the RAP
CCENTERS
  • 1994 FORD RANGER
  • 4 CYL
  • MANUAL
  • 147,000 MILES
I have had the battery tested and the alternator out and tested twice. The battery still will not hold a charge. The truck will stay running as long as I charge the battery. When I am driving the truck it has no power it is dogging out. I have checked the ground wire to the alternator also and it is good. What could be the problem?
BUDDYCRAIGG
  • 2,262 POSTS
Sorry, I dont have any books that will tell me that.
About the what else it could be.
You have a solid state electrical device that has freaked out. It could be anything.
But this might help trace things down.
As a test, only plug in the 22 pin connector and see if you still have the draw.
Then we'll chase down those wires.
