Let me know what you find after reading through that info. and I will follow up.
Thanks for using 2CarPros.com!
Tuesday, February 3rd, 2009 AT 9:40 PM
MGH CUSTOM GRAPHICS
MEMBER
Battery is brand new and alternator still charges when running. Its only when air temp drops below a certain degree
Wednesday, February 4th, 2009 AT 8:14 AM
BLUELIGHTNIN6
MECHANIC
Are battery terminals and wires free of corrosion and tightened properly?
Wednesday, February 4th, 2009 AT 12:44 PM
MGH CUSTOM GRAPHICS
MEMBER
Yes. Terminals are new and tightened properly
Wednesday, February 4th, 2009 AT 6:48 PM
BLUELIGHTNIN6
MECHANIC
You need to get the alternator tested as well to rule that out. Part stores will test for free, on or off of vehicle. Cold weather is harsh on the charging system. There are a few items you can purchase that are really handy in the winter for this problem. A trickle charger will keep your battery charged in cold weather. Heated insulator will keep the battery warm which in turn will keep it charged.
