1994 Ford Ranger Crankshaft Sensor INFO ( CS Sensor )
1994 FORD RANGER
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
XTRAVAGANT1
  • 5 POSTS
i was driving and i somehow broke the magnet sensor off of the CS Sensor and the car come to a quick stop. i then changed the sensor and it still will not start. it seems as if there is still no spark going to the sparkplugs. Do you have any suggestions i can try, i would REALLY REALLY appreciate them!!!!!!!!!!! THANK YOU!!!!!!!!!!!!!!
May 19, 2008 at 12:20 PM
OZMA88
try checking the coil pack or ignition module depending upon what your truck uses. auto zone tests coil packs and ignition modules. if that doesnt fix the problem then the ECC , engine control computer might be the problem
Jun 12, 2008 at 11:15 PM
