2003 Ford Ranger
53,000 MILES • 6 CYL • 2WD • AUTOMATIC
SUE TENNANT
What do you mean by "check for codes"? Where is the crank sensor and how do you check it?
Dec 3, 2008 at 9:29 AM
BMRFIXIT
  • 19,053 POSTS
Hi Sue
try to stay in one post so I can keep track of what we are talking about
you can do so by clicking the (replay to question)
at the lower end of the page
need an OBDII reader to scan for codes
turn ignition key on do u have a check engine light on ?
try and crank the engine does the light go off when cranking ?
crank sensor is located lower front of engine
which V6 do u have
engine size ??
Dec 3, 2008 at 9:39 AM
SUE TENNANT
Engine size is 3.0
Check engine lite is on and goes off when cranked.
Dec 3, 2008 at 10:16 AM
BMRFIXIT
  • 19,053 POSTS
Did you check for spark
do we have spark
does the fuel pump comes on can u hear the pump 1st key on and while cranking
(you should )
remove one of the spark plugs wire place near ground crank engine it should ark and spark
let me know
Dec 3, 2008 at 10:29 AM
SUE TENNANT
Yes, fuel pump is working.
Will have to get back on spark question, no one here to help :(
Dec 3, 2008 at 10:35 AM
BMRFIXIT
  • 19,053 POSTS
just let me know when ready
Dec 3, 2008 at 10:43 AM
