1994 Ford Ranger
XTRAVAGANT1
  • 1994 FORD RANGER
  • 4 CYL
  • 105,000 MILES
I was driving my ranger and it suddenly shut-off on me & wouldn't start back up. So I got the truck back home on my step father's car trailer. I have tried the engine ignition module & the crankshaft sensor. DOES ANYONE HAVE ANY OTHER SUGGESTIONS ON WHAT I SHOULD TRY? PLEASE I AM @ A LOSS.
Wednesday, April 9th, 2008 AT 12:59 PM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
105,000 Check compression, may have a bad timming belt
Wednesday, April 9th, 2008 AT 1:21 PM
