Does this vehicle have a crankshaft posioning sensor
Saturday, November 8th, 2008 AT 6:48 PM
BLUELIGHTNIN6
MECHANIC
Yes. It should be under the crankshaft pully. You need to remove the harmonic balancer and then you will see it. It has three little blocks on it. It should be on the RH side of the front of the block.
SPONSORED LINKS
Saturday, November 8th, 2008 AT 7:04 PM
MECHANIC
A 2.3L has it-on the 2.9/3.0/4.0 6 cylinders-the 4.0 comes with it-CPS
