1992 Ford Ranger rear axle housing vent
TRAPSHOOTER
  • 1992 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 15,000 MILES
I discovered the rear axle housing vent hanging by the tube next to the axle. It appears to have come out somehow, but I can't understand how, as it is still connected to the rubber vent tube which is still clipped to the frame. It could not have unscrewed.
The vent fitting appears to be a different size than the threads in the axle. Is there another piece that screws into the housing and then the fitting screws into that?
Also, it seems that these parts are no longer availabel from Ford. Any idea where I can locate them.
This is really weird, as I have had the truck since '94 and cannot understand how it could have come loose.
Monday, June 9th, 2008 AT 7:53 PM
BMRFIXIT
  • 19,053 POSTS
Possible that  the threads still in the housing
making it look like its a smaller
if you can manage to pull it using an easy out thread remover
I don't believe its going to be an easy job
or try to tap the existing area as is
get your self a brass fitting to fit (home depot hardware store )
Thursday, June 12th, 2008 AT 6:36 AM
