1990 Ford Ranger Four Wheel Drive Automatic
Ok hope someone here can give me some ideas.
I picked up a 1990 ranger 4x4 with a 4.0 this thing starts hard and then it will idle good but when I put it in gear it will run good and then I go about a block and it starts to lose power and it chugs then dies then it is almost imposable to start again when it does start it takes some time to get it to rap up.
I can then drive home again about a block and it starts stalling again.
I have changed the fuel pump relay, fuel pump, PVC, Ignition Control Module, PVC valve and Fuel filter
I have no engine codes
Sunday, July 25th, 2010 AT 10:22 PM
