1989 Ford Ranger Replacing fuel pump & sending unit.
160,000 MILES • 6 CYL • 4WD • MANUAL
AGITA
Hi, I've been told that my fuel pump was bad so I went to replace it. I bought a pump and sending unit combo and dropped the tank and put it in. My problem is of the two lines that supply the fuel, the high pressure (I assume) pushes itself off and leaks. It has a fitting that locks around the nipple and I have pushed it as far as it would go ; as well as locked it multiple times. What could be wrong /I be doing wrong?? Second, would it be a bad idea to cut the fitting off and use a few tighteners to fasten the hose to the nipple?
-Thanks
Mar 3, 2009 at 3:02 AM
IANHIESTAND
  • 14 POSTS
Do not attempt to use clamps or hose due to hazard of breaking off the nipple or softening of the hose leading to failure. Buy new quick disconnect clips and try from there. Being the age of the truck I'd say they are probly frail and broken. Replace them all.
Mar 10, 2009 at 6:31 PM
