HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Engine
Symptoms
Not Running
1986 Ford Ranger Won't start!
DSDUVALL
MEMBER
1986 FORD RANGER
6 CYL
4WD
AUTOMATIC
170,000 MILES
The vehicle will not get power to the fuel pump. I have to prime to keep running. It acts like it's not receiving enough fuel.
Saturday, April 17th, 2010 AT 2:11 AM
MECHANIC
Check the fuel pressure if it's within specs.
Saturday, April 17th, 2010 AT 2:34 AM
DSDUVALL
MEMBER
1 POST
Thank you for your suggestion. Do you have any other ideas
Saturday, April 17th, 2010 AT 3:05 AM
MECHANIC
Check and test the fuse, inertia switch and fuel pump relay-
Saturday, April 17th, 2010 AT 4:31 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
The Engine Cut Out While Driving And The Won't...
The Engine Cut Out While Driving And The Won't Start. The 1st Time It Happened After 10 Minutes It Started. 2 Months Later It Would Not...
Asked by
Daytona#187
1 ANSWER
2006
FORD RANGER
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Disturbing The Engine Timing The Vehicle Cannot Start
Water Went Into The Fuel System. I Removed The Fuel Tank And Fuel Pressure Pump From The Engine And Cleaned Both. After Fitting Both Back...
Asked by
vernon laki
2013
FORD RANGER
The Truck Will Not Start And Shut Off On The Side Of...
I Have An Xlt Model. I Have Fuel Spraying Out Of The Shrader Valve On The Fuel Rail And Both Wires On The Injectors Have Power With Key On...
Asked by
deb74
1 ANSWER
14 IMAGES
1994
FORD RANGER
94 Ranger Turns Over But Won't Start
Starts Maybe One In 10 Times. Turns Over Normally. Runs Rough When It Does Start. Replaced Distrib Cap, Button, Coil, Plugs...
Asked by
cbgaloot
1994
FORD RANGER
My Truck Wont Start It Will Turn Over But Dont Start
It Has Spark And Fuel We Have Replaced Spark Plugs And Wires Distrib Cap And Rotor Both Fuel Pumps Fuel Injectors Fuel Regulator Fuel Filter
Asked by
jsckk9320
1987
FORD RANGER
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Symptoms
