1986 Ford Ranger OIL LEAK
JAMES WOOD
  • 1986 FORD RANGER
1986 Ford Ranger 4 cyl Two Wheel Drive 269000 miles
Oil is coming from somewhere and I cannot locate it the engine has recently been rebuilt prior to my owning. Oill leaks on driver side it appears to be spraying from somewhere valve cover is not leaking rear main seal is not leaking appears to be in vacinity of oil filter or base of the dipstick does not leak unless at highway speed. I got under and looked wiped away all prior oil and that is the only place I could determine how do I find it and how can I fix it? Thank you
Saturday, May 22nd, 2010 AT 4:53 PM
  • 31,937 POSTS
Hi there, replace the oil filter as the seal may be defective, wash down under the engine and take it for a short drive you then may see any fresh leaks forming, start here,
Mark (mhpautos)
Saturday, May 22nd, 2010 AT 9:26 PM
