2003 Ford Ranger Oil Leak and Ticking
Suggested Repair
Confirm the oil level is correct after a full drain and refill, and replace the oil filter, which can rot and leak after long neglect. Monitor for ongoing leaks, ticking, or other problems; two years without an oil change may have caused internal engine damage that could require further repair or an engine.
Conversation Summary
A 2003 Ford Ranger with about 47,000 miles developed a small oil leak. After the oil gauge dropped and the check engine light came on, the engine began ticking loudly. Added oil poured out on the ground, and the oil had not been changed for about two years. A mechanic later reported the engine was running fine, found about twice the proper oil amount, drained and refilled it, and found no leaks. The expert said neglected oil changes may have damaged the engine and guessed the oil poured out of a rotted filter.
