2000 Ford Ranger Unknown Oil Leak
2000 FORD RANGER
85,000 MILES • V8 • 4WD • AUTOMATIC
RGROMM
The truck has an oil leak somewhere on the passenger side of the engine. It has sprayed all over the engine and up onto the headlight. I replaced the missing oil and tried to see if it would leak again and where it was leaking but I cannot seem to find anything. Otherwise the truck runs great! Any suggestions?
Feb 23, 2009 at 3:50 PM
RANGERDANGER17
  • 224 POSTS
okay ford ranger does not come with a v8 so you either meant v6 or you did a engine swap
check the bolts on the valve cover and gasket
you need to pin piont where the leak is coming from
Feb 23, 2009 at 4:42 PM
