start problem
SABAMASA
Where is the ignition module located on a 1997 ford probe with a 4 cylinder engine?
Oct 23, 2007 at 11:29 AM
  • 75,988 POSTS
You sounded like there's no spark
Let me ask you this-do you have a distributor? if not the computer is your ignition control module when it recieves a signal from the Cam/Crank sensors then it fires the coil this where you get spark at the plugs.
Oct 23, 2007 at 10:49 PM
SABAMASA
[quote:fafc4cf16e="sabamasa"]Where is the ignition module located on a 1997 ford probe with a 4 cylinder engine?[/quote:fafc4cf16e] I have a distributor. I bought an ignition module but I can't locate it on the car.
It is the 2.0L.
Oct 31, 2007 at 8:32 AM
  • 75,988 POSTS
What engine is this 2.0L or 2.5L-I've been looking for it-the 2.5 has a distributor but couldn't come up with ICM.
Oct 31, 2007 at 9:15 AM
SABAMASA
[quote:7415bc183c="rasmataz"]What engine is this 2.0L or 2.5L-I've been looking for it-the 2.5 has a distributor but couldn't come up with ICM.[/quote:7415bc183c]
it is a 2.0L
Oct 31, 2007 at 10:49 AM
TIM ROWE
I know this is many years old, did you guys ever find ICM? Factory service manual states it’s part of the PCM. But I have a coil and be a distributor.
Sep 6, 2021 at 10:24 AM
SQM
  • 6,383 POSTS
Yes the ignition control module (ICM) is part of the powertrain control module (PCM) and cannot be serviced separately. The PCM is located under the dash on the center.
Sep 6, 2021 at 2:18 PM
