1996 Ford Probe Loses Oil Pressure
Suggested Repair
Confirm the oil level and check for leaks. If the noise is ticking, oil may not be reaching the valvetrain; if it is loud knocking, suspect a failing oil pump or excessive bearing clearance. Drop the oil pan, clean the oil pickup tube, and replace the gasket where it meets the lower reinforcement so it is not sucking air.
Conversation Summary
The owner of a 1996 Ford Probe says oil pressure is low at startup and drops to zero within about 90 seconds, followed by rod hammering. The engine has oil, a recent filter, no leaks, and no smoke. The expert advises confirming the oil level and leaks, then distinguishing ticking from loud knocking. Possible causes include a failing oil pump, worn bearings, or an oil pickup sucking air; cleaning the pickup and replacing its gasket is suggested.
