1994 Ford Probe Scanner Advice
BESTBET777
  • 89 POSTS
1994 Ford Probe GT V6. What is the best price and usefullness of a scanner for this car?
Where is the year break 1995 or 1996? The ne w scanners now have updateable cards.
What is the info on alternative scanners?
Thanks,
Apr 29, 2007 at 6:40 PM
BACKYARDMECHANIC
  • 337 POSTS
Because your car is a 1994 your car has OBD 1. The down side of OBD 1 is every car manufacture has there own type of connection and system. A scanner for your car may not work for a different make without a different cable or scanner, depending on the type of code scanner. The federal goverment made it mandatory for car companies to have a universal system and OBD 2 was born. The cut off is 1996, however some 1995 models that were manufactured later in the year have OBD 2. As far as the price goes this can vary alot depending on the features of the scanner. I have 2 cars one is OBD 1 and the other is OBD 2. For this reason I purchased a scanner that can work with both systems. The price was around $225 dollars. This cost more then a scanner that just works on one system but I didn't want to be stuck with a tool that I couldn't use after I no longer owned the car.I also made sure that the scanner I purchased was one that can be updated as new tchnology comes out. Generic scanners work and can help with troulbe shooting when needed. Sometimes the scanner can clear a code and that is a that is needed to fix the problem, but don't be mislead that it will fix everything that is wrong with the car because it won't. It helps point you in the right direction and the rest is up to you to find the problem.
Apr 30, 2007 at 12:34 AM
CRAIGFL
  • 89 POSTS
I bought my OBD-I scanner for about $50.00. Check out the auto supply stores and Sears...
Apr 30, 2007 at 4:07 AM
Suggested Repair
For a 1994 Ford Probe, use an OBD-I capable scanner. A dual OBD-I/OBD-II updateable scanner around $225 is useful long-term; basic OBD-I scanners around $50 from auto parts stores or Sears can read codes but only point toward the problem.
Conversation Summary
The owner of a 1994 Ford Probe GT asked about scanner price, usefulness, the OBD year break, and alternatives. The expert explained that 1994 models use OBD-I, OBD-II became mandatory in 1996 with some late 1995 cars included, and recommended an updateable dual-system scanner around $225. Another user reported buying an OBD-I scanner for about $50 at auto supply stores or Sears.
