1996 Ford Probe Battery Gauge Fluctuates
ZEUSWASADELT
1996 Ford Probe SE, 2.0 L, 4 cyl., 128K miles.
I recently had to replace the alternator in this car myself, also replacing the battery and belts. I made my bi-annual drive from college in Florida to upstate NY where I live, about 1100 miles, and everything was fine. However, now that i'm up here, the car's guage showing battery strength is all over the place. Sometimes it's on the high end of the normal spectrum, and other times it drops down to the Low marker almost completely. I have no clue what is wrong at this point, any ideas?
May 18, 2007 at 11:59 AM
RUDPRO
  • 224 POSTS
Sounds like the voltage regulator in the alternator is bad. Take the alternator in to get it tested.
May 18, 2007 at 1:35 PM
RUDPRO
  • 224 POSTS
Correction, your car has an external voltage regulator. Replace it.
May 18, 2007 at 1:38 PM
Suggested Repair
Replace the external voltage regulator. Have the alternator tested as well.
Conversation Summary
A 1996 Ford Probe SE with a recently replaced alternator, battery, and belts shows a battery gauge that swings from the high end of normal to nearly low. The expert first suspected the alternator's internal regulator, then corrected that this car uses an external voltage regulator and advised replacing it.
