95 ford probe 4 cyl 2.0 automactic
1995 FORD PROBE
SHAWN1981
I have tested my battery it is good the alt. is working .but my cars sits to long i have to get it jumped whats wrong? I filled up to a full tank of gas i drove 168 mile to empty what should i check
May 4, 2007 at 12:51 AM
MERLIN2021
  • 17,250 POSTS
with the car turned off connect a voltmeter to the battery terminals. See what it reads. then disconnect the Neg cable and connect the meter with the Pos end to the neg post and the neg end to the cable end, see if you see a voltage drain?
May 4, 2007 at 2:56 PM
SHAWN1981
what about my gas
May 5, 2007 at 12:27 AM
