1993 Ford Probe Seized Engine
If your motor, for example, stopped simply because the bearings melted, (due to inadequate oil) the engine would be rebuildable, however you would most likely need to replace every moving part on the short block (and possibly a few things on the heads as well) have the block hot tanked, checked, double checked and line bored. Then you could be sure it would be last for another 150,000 miles.
I hope this doesn't discourage you. Rebuilding a motor, you being a mechanic will know, is a time consuming, expensive job which i'm sure you will not want to do only ten miles down the road after you've done it the first time. I hope this helps.
Suggested Repair
Tear the engine down and inspect before assuming a bearing-and-ring job. Low oil pressure followed by a lockup often means a bearing seized to the crank, damaging the crank, rod, and mains; a thrown rod may also ruin the block. If damage is limited to oil-starved bearings, a full short-block rebuild with hot-tanking, inspection, and line boring may work. Compare the cost of a crank kit and rod, or a machined rebuild, with a remanufactured engine.
Conversation Summary
The owner of a 1993 Ford Probe GT 2.5L V6 reported oil pressure dropping from about 45 to 25 psi, then knocking near 2000 rpm, and the engine locking up after a few more miles despite a normal oil level. He asked whether new bearings, rings, and a hone would be enough if a rod or crank bearing failed. Experts said a thrown rod often destroys the block and internals, while a seized bearing typically ruins the crank, rod, and mains. They advised inspecting the damage and pricing a crank kit and rod or a full machined rebuild against a remanufactured engine.
