Well razmatz, you aren't going to believe this and it makes no sense. I removed the brand new fuel rail and injectors off the crate motor and put the one off the old motor on. It fired right up. :) DO NOT ASK me why. Could newer injectors later engine requier higher voltage? Well, all I have to do now is get the timing set. It runs, not sure what difference is. Appreciate your thoughts on this. I am going to try the new pressure regulator on the old rail injector system but I doubt that will be it.
Thanks for all your advice, raz.
Dan
SPONSORED LINKS
Friday, March 26th, 2010 AT 5:11 PM
