1993 Ford Probe 6 cyl Front Wheel Drive Manual 140k miles
here is aprevious question, and your answer.
Question: 1997 Ford Probe mileage: 102,000. The car quit while my wife was driving. I am not getting any fire from the distributor. I tried another distributor, crank position sensor, relay and PCM. Still cannot get any fire at the plugs.
Answer: Check the timing belt as it may have failed and consequently the distributor may not be rotating.
The timing belt is fine.
what else could it be.
I have the same problem.
SPONSORED LINKS
Tuesday, October 14th, 2008 AT 2:14 PM
