1991 Ford Probe car won't start ofter rain fall
CABLE255
  • 1991 FORD PROBE
It's fixed right now, something to do with the relay for the fuel pump, power was put too it and it started, we don't know why.
Monday, April 19th, 2010 AT 6:47 PM
  • 109,885 POSTS
Have you checked to see if it is getting spark when it doesn't start?
Tuesday, May 11th, 2010 AT 9:06 AM
GERADAMA1
A likely cause is a cracked Distributor Cap, under high humidity (say rain for example).A crack allows moisture into the interior of the distributor cap causing spark failure. Pull the distributor cap off and inspect very carefully for hairline cracks. (Yes, a razor thin crack can allow the moisture inside).
Wednesday, June 8th, 2011 AT 3:07 PM
