i resently purchased a 1989 ford probe turbo gt 129k.The car was running but battery was replaced and car did not start. Mechanic installed plugs, used distributor, used ignitor coil, fuel pump relay, fuel pump cut off switch, checked fuel pump (OK) air filter, and fuel filter. The car was scanned but not showing any codes. Do you have any ideas why it does not start?
Jun 1, 2010 at 9:19 AM
