1989 Ford Probe 89 Ford Probe won't start
ADAUGHERTY
  • 1989 FORD PROBE
  • 4 CYL
  • FWD
  • MANUAL
  • 127,000 MILES
My probe died while driving would turnover but wouldn't start so I changed the fuel pump and bypassed the inertia switch but will only start when starter fluid is sprayed into the throttle body. Turns over fine.
Sunday, October 3rd, 2010 AT 5:33 PM
Check and test the fuel pump relay-to include a fuel pressure check.
Sunday, October 3rd, 2010 AT 6:01 PM
SINAMAN63
Inside your truck on the drivers side under the lining.(Lift up the board that hides the spare tire). Press that switch for your fuel pump to start working. If the car was hit hard enough on that side it will shut off the fuel pump. Learn that from a State Trooper that assisted me once. Good luck. Cynthia
Sunday, February 26th, 2012 AT 4:20 AM
