1995 Lincoln Town Car Wiper Overtravel
FORD
RAMROD40
I have a 1995 Lincoln T.C. Signature.. it has 228 000 miles on it.. My problem with the wipers is that the drivers side wiper swings too far to the outside , it goes past the edge of windshield about 3 inches at the top edge of blade.. Is there a way to adjust this.
Mar 20, 2006 at 3:52 AM
PEPPERMRJ
  • 1,158 POSTS
Most wiper arms attach by bolt to a knurled shaft. Unbolt the offending wiper arm, remove it, and then reattach it in a position that is 3 inches lower. Tighten the bolt and test.
Good luck and let us know. :)
Mar 20, 2006 at 9:22 AM
Suggested Repair
Unbolt the driver's side wiper arm from the knurled shaft, reinstall it about 3 inches lower, tighten the bolt, and test the sweep.
Conversation Summary
The owner of a 1995 Lincoln Town Car Signature with 228,000 miles says the driver's side wiper travels about 3 inches past the windshield edge and asks if it can be adjusted. The expert explains that most wiper arms bolt to a knurled shaft and recommends removing the arm, reattaching it about 3 inches lower, tightening the bolt, and testing.
