Trunk Lock
SKYWATCHERR
I have a 1995 Lincoln Towncar Presidential Series with 162,000 miles.
When I close my trunk a motor takes over and completes the closing process. When I went to close it a bit ago it would not do that. I noticed that the trunk light is not lit when the trunk is open.
Are these realted and how do I check to see if i have a fuse or mechanical problem or both?
Thank You
Pastor Rich
Oct 31, 2007 at 11:01 AM
BLACKOP555
  • 10,386 POSTS
check for voltage at the motor. if there is voltage then change the motor or switch to turn it on. if no voltage look for a blown fuse in your fusebox.
Oct 31, 2007 at 11:54 AM
