2002 lincoln towncar-headlight assembly/hood latch
MCELERI
2002 lincoln town car signature, 60,000 miles,v8?
How do I replace the driver side headlight assembly?
Also, the primary hood latch won't close, the cable is movng- the spring is moving, but the actual closing part doesn't close over bar when hood is dropped. Any thoughts?
Thanks for any help! :)
Jul 26, 2007 at 12:47 PM
MERLIN2021
  • 17,250 POSTS
Headlight assy is one of the simplest I've ever done. Look for three black handles, pull them out 1 at a time the light is now out! Try a little lube on the hood latch!
Aug 12, 2007 at 12:07 AM
MCELERI
[quote:445307cdc7="merlin2021"]Headlight assy is one of the simplest I've ever done. Look for three black handles, pull them out 1 at a time the light is now out! Try a little lube on the hood latch![/quote:445307cdc7]
Thank you very much for the help, The lube idea was fantastic-worked like a charm- i'm a little embarassed I didn't think of that!! :-) And I;m going out right now to try the head light!
Aug 12, 2007 at 3:31 AM
