2002 Ford Explorer Transmission Jerking
FORD
BRITTANYOG
2002 Ford Exploer xlt
97,000 miles
v8
A week ago the overdrive f light began flashing, and at the same time when the vehicle shifts into 3rd it jerks and you can hear it. When it shifts down into 1st gear it also thumps a little. The check engine light is not on. Could this be the transmission going out or sensors? Otherwise teh car runs fine it does not slip or grind.
Jun 24, 2007 at 7:37 AM
INDYUKE
  • 416 POSTS
When the overdrive light flashes, it indicates the computer sees a fault in the transmission somewhere.
And it is my understanding that when the computer sees a fault in the transmission, it will increase line pressure thus making the shifts feel more firm. First find out why the overdrive light was flashing. That will point you in the right direction.
Jun 24, 2007 at 7:10 PM
Suggested Repair
Diagnose the flashing overdrive light first by retrieving the transmission fault the computer detected. Firm or jerky shifts can result from raised line pressure after a fault, so identify that fault before assuming the transmission is failing.
Conversation Summary
A 2002 Ford Explorer with 97,000 miles jerks when shifting into 3rd and thumps slightly into 1st while the overdrive light flashes. There is no check engine light, slipping, or grinding, and the vehicle otherwise runs fine. The expert explained that a flashing overdrive light means the computer has detected a transmission fault and may raise line pressure, making shifts firmer. The first step is to determine why the overdrive light flashed.
