Ford Ignition Rotor Wrong Position
FORD
JONS89PGT
  • 8 POSTS
what's the worse thing that can happen if I reinstall the rotor in the wrong position? Old one was beat up and got a replacement rotor and cap but am not sure how it goes back...
thanks
Mar 14, 2007 at 4:11 PM
TAURUSWHEEL
  • 718 POSTS
The rotor is keyed, it'll only go back one-way. You need to make sure you re-install the sparkplug wires correctly to the cap, each has it's own place.
Mar 15, 2007 at 4:04 PM
JONS89PGT
  • 8 POSTS
thanks
got everything back on correctly.
The plugs were really hard to get out.
I put a small amount of dielectric grease on the threads, normally I'd use lithium grease but I couldnt find it. DO you think dielectric grease would be ok?
Mar 16, 2007 at 6:44 AM
TAURUSWHEEL
  • 718 POSTS
Yeah, that should be fine.. also supposed to use the grease around the sparkplug where it fits into the boot, what I usually do is just squirt a bit into the boot end also a small film on the tip of the rotor... I use a small amount of anti-seize on the threads myself...
Mar 16, 2007 at 10:32 AM
Suggested Repair
The rotor is keyed and should only install one way. Reinstall each spark plug wire in its correct cap position. Dielectric grease is acceptable in the plug boot and as a light film on the rotor tip; anti-seize is preferred on the plug threads.
Conversation Summary
The owner asked what could happen if a replacement distributor rotor was installed in the wrong position and later asked whether dielectric grease was acceptable on hard-to-remove spark plug threads. The expert said the rotor is keyed so it only fits one way, and the important step is putting each spark plug wire back in its correct cap location. Dielectric grease was said to be fine in the plug boot and as a light film on the rotor tip, while anti-seize is preferred on the threads.
