1993 Ford Taurus High Idle After Battery
FORD
NAENAE882001
  • 6 POSTS
I STOPPED FOR GAS AFTER I HAD BEEN DRIVING MY CAR ABOUT 45 MINTES, AFTER PUMPING I GOT IN AND IT WOULD NOT TURN OVER. IT ACTED LIKE IT WAS A DEAD BATTERY OR MAYBE THE REGULATOR ???? ANYWAY AFTER BEING TOWED TO THE SHOP THEY TESTED ALTENATOR & REPLACED BATTERY. WELL EVER SINCE MY IDLE HAS BEEN AT 3000 WHEN I AM AT A STOP. IT GETS UP TO 4500 AT 70-75 MPR ??? WHAT GIVES ??
Aug 19, 2006 at 6:29 AM
NOS
  • 320 POSTS
What kind of car and engine are we talking about ?
if your close to the same shop the may need to rest the computer.sometimes after disconnecting a battery it will feed wrong info to sensors. or visa versa they will have to hook up scanner to rest comp kinda sounds like a ford
Aug 20, 2006 at 4:31 AM
NAENAE882001
  • 6 POSTS
MY CAR IS A 1993 FORD TAURUS SHO 3.2 ?? SORRY ABOUT THAT.
Aug 21, 2006 at 5:53 AM
NOS
  • 320 POSTS
there is a thing called an IAC motor which controls the idle and it may need cleaning the get carbon under the and them and the valve won't close so it makes the idle high.they are mounted on the side of the throtle body and has two wires going to it some times lightly taping on it will free it up.there are two kinds one has a plastic diaphram in it and they get cracks in them if this happens they need to be replaced so you kinda need to know which one you have. the only way to know this is to remove it and look whilr it is off you can spray carb sleaner in it to clean it. it has two 5/16 head bolts holding it on try not to tare the gasket. (NOS)
Aug 21, 2006 at 10:45 AM
NAENAE882001
  • 6 POSTS
I will try that in the morning and let you know. Thank You.
Renee
Aug 21, 2006 at 5:25 PM
NAENAE882001
  • 6 POSTS
Well that didn't help. how do they reset the computer??? :roll:
Aug 23, 2006 at 10:15 AM
NOS
  • 320 POSTS
they have to use a scanner to reset do you possibly have a service engine soon light on or a check engine light on? if so this could also tell the tech what is going on with your car before they reset it. if your not sure about the cleaning of the iac let them do that also.sometimes answering the questions is difacult not being able the listen to the car or hear what it is doing it sounds like also that the last people that did the alt knocked a vaccum line off when they did the alt .stange that this started after they did the work. i'am trying to be as much help as posible.(NOS) :D
Aug 23, 2006 at 12:36 PM
NAENAE882001
  • 6 POSTS
SO I HAVE TO HAVE A REPAIR SHOP RESET THE COMPUTER ??? I HVE CHECKED OUT ALL THE VACUUM LINES THAT I COULD WITHOUT FINDING ANY DISCONNECTED. I SURE LOVE THIS CAR BUT WHAT A RE[AIR NIGHTMARE! :?
Aug 23, 2006 at 1:33 PM
NOS
  • 320 POSTS
i'am affriad so. But something is going on with it. this didn't start till they did the battery thing.so by them disconnecting the batter and takeing voltage from the computer i can only assume that is where the problem is that it is receving the wrong info now and needs to be reset. we only chage 35.00 dollars for hook up of our scanner so surely it wouldn't be much more than that unless you take it to a dealer then you gona get took. (NOS) i would like to fix every car i hear about but sometimes it's not posible cause i can't see or hear the car. so i can only go buy what i'am told.
Aug 26, 2006 at 1:52 AM
NAENAE882001
  • 6 POSTS
front oil seal leak, talk to me
Oct 9, 2006 at 1:56 PM
Suggested Repair
Have a shop scan the vehicle and reset the computer after the battery disconnection. Also check for a check-engine light, inspect vacuum lines that may have been disturbed during the alternator work, and have the IAC motor inspected, cleaned, or replaced if needed.
Conversation Summary
A 1993 Ford Taurus SHO developed a very high idle after the battery was replaced and the alternator tested. The expert suggested cleaning or replacing the IAC motor, checking for a disconnected vacuum line, and using a scanner to reset the computer. The owner reported that cleaning the IAC and checking accessible vacuum lines did not help, and the expert advised having a shop perform the computer reset and further diagnosis.
