2003 Ford Taurus Low Idle Lag
HOUSEOFPAYNE
2003 Ford Taurus 61500 miles. Noticed that the car would lag when i gave it gas. Rpm would go down to 500 and up to 1000, but pretty much bounces back and forth from 500 to 700 rpm. Check Engine light started blinking and then after a few minutes stayed on. Check it with OBD II scan had no codes. Seems to throttle low and then it cathces up and seems fine (catch up) then it feels like its struggling again especialy when i accelerate.
Apr 12, 2007 at 6:39 AM
MERLIN2021
  • 17,250 POSTS
This one sounds like the idle air controller. Most times they don't set a code! The other culprit is the Mass airflow sensor, That dosent usually set a code either and you get kinda the same problem. Try unplugging the MAF with the car off, then start it. Does anything change? then do the same with the IAC.
Apr 12, 2007 at 6:51 AM
Suggested Repair
With the engine off, unplug the mass airflow sensor, then start the car and note any change. Repeat the same test with the idle air control valve. Either component can cause low, surging idle and hesitation without setting a code.
Conversation Summary
A 2003 Ford Taurus with about 61,500 miles lags under acceleration, with idle bouncing roughly between 500 and 700 rpm. The check engine light blinked, then stayed on, but an OBD-II scan showed no codes. The expert suggested the idle air control valve or mass airflow sensor and recommended unplugging each one with the engine off, then starting the car to see whether the symptom changes.
