ford falcon ef rear diff/wheel noise
FORD
95FALCONAUS
Hey i have a 1995 Ford Falcon EF 4.0L 6 cyl done about 220,000ks and just recently something happened with my diff or wheel on the driver side now when i turn corners and stuff it groans squeaks and sometimes makes a banging noise. Any ideas on what this might be as im out of ideas?
Nov 9, 2007 at 5:16 PM
  • 31,937 POSTS
Hi there,
First check the diff oil level, check for oil leaks around the rear wheel bearings, (at the end of the diff housing) check universal joints foe excessive movement, A diff bearing noise will normally be fairly constant with road speed and throttle setting, they will change noise pitch when you come on and off the throttle (normally) wheel bearings will howl at a constant rate, regardless of throttle load, also make sure that the brake caliper has not come loose, another common problem is that the hand brake cable & or caliper actuator sticks on, you should be able to move the lever on the rear of the caliper (handbrake actuator) and it should return with the spring to it's off position. there are a few things for you to check.
Mark (mhpautos)
Nov 9, 2007 at 10:20 PM
95FALCONAUS
thanks i will do all that and see if it is one of those but yea it probably is something with my brakes cause when i turn it seems to lock the right rear wheel and it drags.
Nov 10, 2007 at 7:42 AM
