I have a '68 Ford Mustand coup with a 302 and unk milage. I rebuilt the engine and have everything back together except for the distributor. I can't get it to go back in all the way. When I set it down there is about a eigth of an inch to go before I can get the keeper bolt in place. I think that it is the oil pump drive rod that is not lining up correctly. Its a hexagonal shaft that fits into the female portion at the end of the distributor. I'm pretty sure that the gears with the cam are lining up correctly. I'm frustrated because its such a small part that so important.
Feb 11, 2007 at 2:39 AM
