Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Other
Ignition
No Spark
no spark
FORD
JFRANK
MEMBER
FOLLOW
I have a 1989 ford 300 in a half ton pickup and I have no spark what is the most likely problem?
Mar 7, 2006 at 10:52 AM
EPYON2K1
MEMBER
Hey check the timming, if not, for good connection with the spark plugs, coil, Replace the ignition relay..... Hope this helps....
Mar 7, 2006 at 12:28 PM
PEPPERMRJ
CERTIFIED EXPERT
TFI module, EEC IV module, and the coil, in that order. Here is a link on how ot test each.
Also some auto parts stores will be able to test the components if you take them in.
Good luck and let us know. :)
Mar 14, 2006 at 5:17 PM
