1996 Ford Escort No Spark No Start
FORD
TOMMAS123
my 1996 ford escort estate 1.4 xl manual box petrol with 132000 on clock was running fine,it now will not fire up,petrol pump seems ok,it just cranks over.
The engine is transverse with timming belt facing the passenger side,distributor all in one with the engine,and has leads marked 1 to 4 no centre lead. there is no spark and i was wondering if the ignition module needs replacing,where would i look for it..thanks
Nov 13, 2007 at 6:13 PM
BLACKOP555
  • 10,386 POSTS
ignition module is usually on side of distributor.
i think you may have a bad coil. have it tested first.
Nov 13, 2007 at 10:57 PM
Suggested Repair
Test the ignition coil first. The ignition module is usually located on the side of the distributor.
Conversation Summary
The owner of a 1996 Ford Escort reports that the engine cranks but will not start and has no spark, though the fuel pump seems to work. They asked where the ignition module is located. The expert said it is usually on the side of the distributor and recommended testing the coil first.
