break switch
FORD
JIMLARA
  • 6 POSTS
to replace the brake switch in a towncar you have to remove the plastic covering under the dash that covers the switch there should be three plastic push in plugs that you have to pry out and the cover will come off and you will be able to see the brake switch above the petal. remove thye wireing clip. then a pin holds the switch in pos. rev. the process to install
May 27, 2006 at 7:27 AM
PLYNNE53
lincoln towncar 1994 100,500 how do you fix a break switch thats under your break pedal
May 23, 2006 at 6:17 PM
JIMLARA
  • 6 POSTS
