1949 Ford F-1 Brake Lights Out
FORD
BRASFIELD
I removed an aftermarket turn signal set-up on an old 1949 Ford F-1 pickup, and reconnected (I think) all the proper original wires. All the lights work correctly, except that when the tail lights are lit and I step on the brakes, the lights go out completely until I let up on the brake pedal. The brake lights work fine if the tail lights are not on. I have tried changing the wires on the brake light switch, but it has no effect. Any suggestions? I am sure it is something relatively simple, but I'm stumped.
Mar 4, 2007 at 8:22 AM
NOS
  • 320 POSTS
have you tried grounding the receptacle to see if it may possibly have a bad ground? 8) NOS
Mar 4, 2007 at 12:06 PM
BRASFIELD
[quote:f6ac59e193="NOS"]have you tried grounding the receptacle to see if it may possibly have a bad ground? 8) NOS[/quote:f6ac59e193]
That was the solution - thanks!
Mar 6, 2007 at 4:06 PM
NOS
  • 320 POSTS
would like it very much if you would vote for me for helping you out feed back is always welcome 8) NOS
Mar 8, 2007 at 12:25 PM
MIKE H R
  • 3,094 POSTS
check the bulbs, one could be shorting out, if they are clean and the bulbs are good , check the wires that go to them one is the tail light feed and the other is the brake light feed with a test light. if the wires are working all right , then check the ground on all the lights.
Mar 9, 2007 at 5:55 AM
Suggested Repair
Check and repair the ground at the tail and brake lamp receptacle. A poor ground caused the lights to go out when the tail lights and brake lights were both energized.
Conversation Summary
The owner of a 1949 Ford F-1 reconnected the original lighting wires after removing an aftermarket turn-signal setup. The brake lights worked alone, but with the tail lights on they went out when the brake pedal was pressed. An expert suggested testing the receptacle ground, and the owner confirmed that a bad ground was the solution.
