Ford Brake Lights On With Key
FORD
CAVGUY1964
whenever i turn the key on my brake lights come on and the only way to get them to go off is to unhook battery
Mar 13, 2006 at 3:35 PM
RAYHUT
  • 134 POSTS
you either have a short going from your ignition to your break lights or a sensor that reads your electrical cuircut is bad.
Mar 13, 2006 at 9:18 PM
PEPPERMRJ
  • 1,158 POSTS
Check the brake light switch.
Good luck and let us know, :)
Mar 14, 2006 at 12:47 PM
Suggested Repair
Check the brake light switch. Also consider a short from the ignition circuit to the brake lights or a faulty sensor that reads the electrical circuit.
Conversation Summary
The owner of a Ford (year and model unknown) reports that the brake lights come on whenever the key is turned on and only go off after the battery is disconnected. One expert suggested a short from the ignition to the brake lights or a bad circuit sensor. Another expert recommended checking the brake light switch.
