1990 Lincoln Mark 7 Air Ride Front Down
FORD
DARKWARRIOR
my daughter has a 1990 lincoln mark 7 she bought used the entire front end is sitting down on the front tires. i have read a little about the air ride system is there a way for me to get a idea of whats wrong she is sixteen with a little money the car runs good just cant drive it is it worth fixing. thank you.
Jan 18, 2006 at 1:21 PM
HEAVNZ_WARRIOR
  • 8 POSTS
My dad has the same exact car.. basically what ford told him (since he had the same problem but in the rear) that it was a control module that causes the car to lift up when the ignition is turned on... And that he would have to replace that.. They said it would cost about $1200 to fix it... Also the front airbags may have gone out, if so each one is about $400.. Of course im just guessing since my dad has gone through this, but that would be my answer.
Also the front is made to sit on the tires when the car is cold ( On ours it took about 30-60 mins for it too completely deflate and the front end to sit on the tires) Does it rise up at all when the igniton is turned on? Crank it up and wait about 10 minutes and if everything is functioning properly you will see it rise up very slowly.
Jan 18, 2006 at 8:58 PM
SC1 RACING
  • 117 POSTS
i have been working on one lately. it shouldnt take a min or two for the car to rise, and it should never drop down unless there is a leak. you have a ride height sensor on each of the front wheels. check to make sure they are hooked up. but you will still have problems due to a leak. eventually it will burn the compressor up if not fixed. you can get new air bags at alot better than 400.00 but remember ford says the life span is 4 years, so i would sugest a change over kit. it comes with new springs/ shocks, and strutts. you can get front and rear kit for under 400.00 and never worry about the pos air ride of a ford.
the whole swap over took me 2 hours. do a web search on ford air rides and you will find the kit or i will try to find the site again.
Jan 20, 2006 at 6:25 AM
PBLOSTVNS
check out arnott industries online they specialize in lincoln air suspensions
i was reffered to them by a lincoln dealership when it they said it would cost more to replace the electronic than my continental was worth. they have all the parts you need at a fraction of the dealer cost and they stand by their products
Jan 21, 2006 at 1:37 AM
Suggested Repair
Confirm the front ride-height sensors are connected. The car should rise within a minute or two of startup and should not settle unless there is a leak, which can eventually damage the compressor. Rather than costly dealer air-ride repairs, consider a front-and-rear spring, shock, and strut conversion kit (reported under $400 and about a two-hour install), or source air-suspension parts from a specialist such as Arnott Industries at below-dealer cost.
Conversation Summary
The owner of a used 1990 Lincoln Mark VII said the front end sits on the tires and asked whether the air-ride system is worth fixing on a small budget. One commenter relayed a dealer estimate of about $1200 for a control module and about $400 per front air spring, and said the front can settle when cold. An experienced reply said the car should rise quickly and should not drop without a leak, advised checking the front ride-height sensors, warned that a leak can burn out the compressor, and recommended a spring conversion kit under $400. Another commenter suggested Arnott Industries for Lincoln air-suspension parts at a fraction of dealer cost.
