1995 Other Ford Models
1995 FORD
75,000 MILES • 4 CYL • FWD • AUTOMATIC
JENNY0
i have been getting alot of white gunk in my car in the oil cap and air system, its a fiesta, the white gunk has been cleaned out but keeps returning, i am not losing coolant and it never over heats or even goes past the quarter mark. can you explain why this keeps happening
Jan 14, 2008 at 11:37 PM
  • 31,937 POSTS
hi there,
this is condensation building up in the engine, you are probably not doing a lot of miles, i would say many short trips, the engine is not getting up to normal operating temp often enough to burn off this moisture properly. add a tin of engine oil flush and go for a long drive, change the oil & filter, this will help but will not solve your problem, getting the engine up to full temp often will be the best thing to do.
Mark (mhpautos)
Jan 15, 2008 at 1:46 AM
