1994 Chevy Lumina Overheating Head Gasket Fix
Once you disassemble the front of the engine, place it in neutral and rotate the engine to access the back side.
Once you disassemble the front of the engine, place it in neutral and rotate the engine to access the back side.[/quote:dbe5bed78d]
HI,
Thank you for the reply. One question about rotate engine to check the pistons in the back or is this a trick to get to the back head easier. Can you please explain about this Thank's
Suggested Repair
Treat it as a head-gasket job and top-end the engine: service both heads, replace both head gaskets, and have the heads checked for cracks and warping. If the piston tops look acceptable, reassemble. For rear access, loosen the front dog-bone engine mounts, put the transmission in neutral, and roll the engine forward; some mounts have a second hole to hold it in that position.
Conversation Summary
The owner of a 1994 Chevy Lumina minivan with a 3.1 engine reported overheating, a rough idle, high fuel use, a loose PCV, and codes for a high-temperature coolant sensor and a rich O2 sensor, with no coolant in the oil and no exhaust smoke. A shop diagnosed a rear head gasket and quoted $2,000. The expert agreed it was the head gasket and recommended servicing both heads, replacing both gaskets, and checking the heads and piston tops. Access to the rear is improved by rolling the engine forward after loosening the dog-bone mounts with the transmission in neutral.
