1996 Chevy Lumina Oil in Coolant
DANNY_R
Hi everyone. I've got a 96 Lumina with the 3.1L which has 89,000 miles. I was doing a routine checkup on the fluids and unscrewed the radiator cap and was horrified to find oil spewing out, looked like runny peanut butter! I flushed the cooling system the best I could but oil is very hard to remove. I began reading about the 3.1 and how its prone to intake gasket failure. However what’s puzzling me is if it was an intake gasket failure then surely I’d have water leaking somewhere from the engine? and if it was head gasket failure then I’d probably have steam coming from the exhaust! but in my case I don't. So what do you guys think it could be?
Kind Regards
Danny
Aug 28, 2006 at 3:27 AM
MIKEYBDMAN
  • 623 POSTS
[quote:a99bc035e8="Danny_R"]Hi everyone. I've got a 96 Lumina with the 3.1L which has 89,000 miles. I was doing a routine checkup on the fluids and unscrewed the radiator cap and was horrified to find oil spewing out, looked like runny peanut butter! I flushed the cooling system the best I could but oil is very hard to remove. I began reading about the 3.1 and how its prone to intake gasket failure. However what’s puzzling me is if it was an intake gasket failure then surely I’d have water leaking somewhere from the engine? and if it was head gasket failure then I’d probably have steam coming from the exhaust! but in my case I don't. So what do you guys think it could be?
Kind Regards
Danny[/quote:a99bc035e8]
I would guess head gasket, but I have been wrong before. Start taking it aprat and see if you can find the leak at the intake. If not, remove the heads and see if the gaskets are starting to leak. I know on the 3.1L the push rods go thru the edge of the intake, so it is possible the oil could have gotten in there.
Aug 28, 2006 at 7:49 AM
SYNCRAIT
  • 235 POSTS
I agree on the intake gasket but if your worried about the head gasket you can always do a compression check....also if your up to it the intake gasket is usually one of the easiest to replace yourself if you have a spare afternoon and a load of patience...good luck lemme know :)
Aug 30, 2006 at 11:11 PM
FLINTBRAD
I think you should check the radiator tank on the transmission side to see if it has an internal crack. also check if your transmission fluid is low. it may be going into the radiator. if you think you may have a bad headgasket you might want to have the engine block tested to see if you are getting exaust gases in your radiator. and pressure test the cooling system to see if you are loosing coolant into any of the oil systems. If the radiator has pressure in it, then you should see the leak from the gaskets on the head or intake. You should also check the oil in the car and see if you see milky white condensation on the dip stick or in the oil fill cap.
Sep 6, 2006 at 2:55 PM
Suggested Repair
Diagnose before replacing parts. Inspect the intake gasket first, since the 3.1L pushrods pass through the intake edge and can let oil into the coolant. Do a compression or block test for exhaust gases in the radiator and pressure-test the cooling system. Also check the radiator transmission cooler for an internal crack, transmission fluid level, and the engine oil for milky contamination.
Conversation Summary
A 1996 Chevrolet Lumina 3.1L owner found oil mixed into the coolant, with no external coolant leak or steam from the exhaust. Experts suggested the intake gasket as a common cause, a possible head gasket, or transmission fluid entering through a cracked radiator cooler. Recommended checks include inspecting the intake, compression or exhaust-gas testing, a cooling-system pressure test, and checking transmission fluid and engine oil.
