1992 Lincoln Continental, everything is electronic (stupid computer chips attached to everything).
The spring at the latch that operates with the outside door handle broke. The door remains locked. Everything in the car is electronic. The interior lights stayed on because the door would not close and latch properly, hence the battery is dead. The door handle on the inside of the door does nothing to open the door. The pull lock on the inside of the door remains locked, whether there is power or not; I can't pull it up to unlock the door.
I need to remove the door, replace the broken spring and reattach the door properly.
How do I remove a door where none of the door handles work and the door will not unlock whether by manual or electronic means?
I have removed the bolts that hold the door to the frame, hoping that I could manually pop (or rip) the door off, but there is a mechanism at the door latch that simply will not allow me to remove the door.
The car is 17 yrs old, I bought it for a buck from my Grampa, the engine only has 60,000 miles, it actually runs great and gets 27mpg, I want to fix the dang door - How do I do it?
Thanks for your help!
Best Regards,
Geoff FitzGerald
Best Regards,
Geoff FitzGerald
Jul 23, 2009 at 6:55 AM
